anybody have trouble getting the kelsey repo(goodyear custom super cushion 6.70 x 15) mounted on an original K/O installed in an original unmolested tire tub? mike
kelsey repo tires fitment in spare tire tub
Re: kelsey repo tires fitment in spare tire tub
Mike,
Are the bolts that hold the lid the correct length for KO wheels ? I believe they make a couple different lengths depends if steel wheels vs KO's.
Mike- Top
Mike -
The DOT requirement for inflation when the tire is still hot out of the mold makes the reproduction tire slightly larger in both cross-section and diameter than an original tire of the same size; that may be contributing to the problem.- Top
That explains why I had to get the longer bolts made for the redlines to make my new Kelsey GY PC's whitewalls (775X15s) in my '67's spare tire tub.Big Tanks In the High Mountains of New Mexico- Top
I kinda figured you did. Years ago they had machines that would shave tires down for racing or if a tire was out of round it would true it up, maybe there's one close to you somewhere.
Mike- Top
no tire shops around here that'll grind down the OD. i'll just mount it on my daily driver, a chevy pickup with a LS3 525 HP crate engine. few burnouts ought to do it. thanks for good suggestion. mike- Top
