54 wire harness installation proceedure? - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 499
    Im trying to figure out which way to feed the harness thru the 1 inch hole in the firewall. I started to feed the insrument wires thru from the engine side buy doent seem to work. The thickness of the harness and light bulbs seems too much. Also doesnt seem the column connectors will go thru with the thickness. They must of had a proceedure at the factory. Is it better to feed the engine side of the harness from inside the car because doesnt seem the the point where it takes off to the generator, that junction, will fit thru that hole without really compressing it. How did you folks feed it? Thanks as always.
  • Dan D.
    • November 5, 2008
    • 1323
    Re: 54 wire harness installation proceedure?
    Guy, on 56-57 you feed the wires from under the dash and into the engine compartment. Not sure on your 6V 54 - generator is on the right side. But I think this is still correct and you can get the wires through if you try hard enough. Feeding from the engine you wont get the light bulbs and connectors through, as you say.
    -Dan-
    • Chris S.
      • January 1, 2000
      • 1064
      go from the passenger compartment thru to the engine bay......
      you can open the hole slightly if need be...
      It will fit -
      Also if you have some sun - set the harness in the sun so it is warm and flexible.....
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 499
        Excellent! Thanks again, alot going on now all at once pulling it together. I will have more questions soon im sure and maybe others will benifit from this when they get to this point.
