is there supposed to be an actual pcv valve on my 1964 corvette if so where would it be? hose from oil fill tube to carb. and hose to air cleaner to crank case only no actual valve in place.
PCV valve
Re: PCV valve
Ward------
No PCV valve was used on 1964 Corvettes. There was a positive crankcase ventilation system but no actual valve was used. Instead, a "calibrated orifice" was used.In Appreciation of John Hinckley- Top
Re: PCV valve
Ward -
The PCV configuration depends on which engine you have - the 250hp and 300hp engines use a restrictor fitting where the hose from the oil fill tube connects to the rear of the carburetor baseplate (Assembly Manual, UPC 6, sheet C3.00), and the L-76 365hp engine uses a different restrictor fitting on the driver's side of the Holley carburetor main body.- Top
