Re: Distributor Lower Bushing Excessive Wear History
Interesting about the replacement shafts. I've never used one nor looked at them. Always managed to round up a good used original. The surface being "rough" is odd. I would expect that shaft to be ground to a check 4 finish. Should appear as almost polished for bronze or oil lite applications.
My honest opinion is the shaft and bearing are both not up to the task. Be it finish, hardness or material they are less than what you need. You have a new longer bearing with oiling at pressure, why not acquire an original used shaft to try out? That is the easy fix to accomplish. This eliminates two questionable variables, hardness and finish, possibly even material. Your .004" clearance should work well with pressure.
Make sure the bearing bore surface is smooth with out reamer marks. I'm not sure bronze responds well to hone stones but that would only increase shaft/bore fit making it too big. That shaft is only about 1/2" or there abouts. Glass paper or crocus cloth should work.
