54 grommet question - NCRS Discussion Boards
54 grommet question
  • Guy M.
    • November 1, 1993
    • 499
    54 grommet question
    I have two grommets in my kit measuring 1 3/4" wide, 3/8" thick with a 3/4" inch hole. The side is slightly concaved. Any idea what these two are earmarked for?? They are a spongy material. To big for choke cables. Thanks again
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 54 grommet question
    photo ??????
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Dan D.
      • November 5, 2008
      • 1323
      Sounds like they may be for the throttle 'Z' arm where it goes through the firewall. This would be for V8s, not sure hat the 6 looks like.
      -Dan-
      • Guy M.
        • November 1, 1993
        • 499
        Here is the grommets that I have but I dont think they go to 54, anyone have a good pic of the grommet at the choke cables? Thanks again photo 2.jpgphoto 1.jpg
        • John L.
          • February 1, 2005
          • 207
          Hey Guy - you probably figured this out already .... i am just starting to look at the grommet holes on my 54 .... did you find that these two donuts were for the heater core outlets that poke through the firewall???
          John Lanning
          • Guy M.
            • November 1, 1993
            • 499
            No, I think they go to 55. There are no grommets for the heater core lines. Note to self........Install the wiper motor and have it hooked up the the switch cable before setting the body drop. So much easier.
            • Chris S.
              • January 1, 2000
              • 1064
              Guy
              There are "insulators" or seals that go on the heater core - and seal against the firewall when the heater case is installed.
              • Cathy S.
                • August 31, 2003
                • 293
                Heater core
                • Guy M.
                  • November 1, 1993
                  • 499
                  Thank you, schooled once again. Mine didnt have any back when I removed it so I wasnt looking for it. The Grommet kit doent say which goes where and I didnt read anything anywhere to tell me. Just one more piece to the puzzle. Im still short the grommet to the main harness so I have to find that one as my kit seemed short.
                  • Chris S.
                    • January 1, 2000
                    • 1064
                    There was not a grommet for the main harness (that I have seen)
                    Typically it was a rough cut hole and then back filled with dum dum....
                    I have not seen one with a grommet -
                    Others may chime in
                    • Guy M.
                      • November 1, 1993
                      • 499
                      Well thats really good to know, Ive been pulling my hair out looking at original cars trying to figure this out. I suppose I could use dum dum at my heater core sisce its already installed. I dont want to take it out now for the grommet. We can wright a book on all these missing pieces. Someone go for it. Thanks Chris!
                      • Chris S.
                        • January 1, 2000
                        • 1064
                        when you get the heater hoses on - hard to tell if the seal is in there.....
