While I'm waiting for the machine work to get done on my L76 I've started to rebuild the distributor. The Tach quit about 30 years ago so I knew that I would be replacing the main shaft and the tach drive gear. From what I've read most failures are caused by sloppy lower bushing and sure enough it's pretty loose when compared to the upper. That brings up the first question, should I leave the upper bushing alone if it seems tight? Also how does someone measure clearance on such a part?
LIC sells a main shaft for my application that Joe Ciaravino has verified the "football" for centrifugal advance is installed correctly so I'll be going with that part for the main shaft. I know I should replace the lower bushing but should I also replace the upper? It goes without saying I want to replace all wiring and the grommet because it's dried out and cracking. The ground wire also looks really gnarly and should be replaced. I've attached a photo of the base plate that I would like to save if the wire can be replace and be reliable. It looks as though it might be silver soldered to plate? What methods have other folks used to replace this wire. LIC sells a wire with the terminals attached that looks to be a good part based on the image.
The next question is about cosmetics. The '65 JM doesn't mention paint at all on the distributor housing yet I assume it was painted. My question is was it painted prior to machining or after? If it was painted prior to machining then some raw machining should probably be exposed.
Mike
Mike
