Fail PV if high-pressure oil pump??
Re: Fail PV if high-pressure oil pump??
Mike------
YUP! I absolutely do not recommend the use of single viscosity oils for a street Corvette. That was OK back in the 60's and 70's but definitely not now.In Appreciation of John Hinckley- Top
Bruce------
If you mean does it have to come off the engine to change the relief spring, the answer is no. However, you should have no fear about removing the pump anyway because one bolt and it's off. It couldn't get much simpler.In Appreciation of John Hinckley- Top
Bruce -
Absolutely! CJ-4 15W40 oil has more than adequate zinc/phos (ZDDP) concentration to provide protection for any OEM valvetrain. Get rid of that straight-weight oil - it became obsolete 40 years ago (and stop listening to "engine-builders").- Top
- Top
Jerry------
Use a Melling #10553 and install the yellow spring that's supplied with it.
If you have an original pump it might be OK, as-is. Open it up and note if there's any wear on the bottom plate. Then, check the gears for scoring. If it checks out, it should be OK for re-use. Oil pumps are well lubricated (to say the least) and often suffer little wear even at high mileage.In Appreciation of John Hinckley- Top
Mike---
All C1 used standard pressure oil pumps.In Appreciation of John Hinckley- Top
Thanks for the info Joe. I was responding to the OP about his '66 L79. But I always learn a lot from all the posts I read. Now I know a little more about C1 motors. I know that some of the C2 fuelies and solid lifter small blocks had 80lb gauges. Did they have higher pressure pumps as well, or just higher reading gauges? And did the later C1 fuelies and solid lifter motors, like the 62's, have the standard pressure pumps?
Mike- Top
Bruce,
You will find the needed torque specifications in your copy of the Chevrolet Overhaul Manual for your year Corvette.Terry- Top
