Re: Fail PV if high-pressure oil pump??
The first and best option is to use the original pump. They're easy to disassemble and inspect and rarely show much, if any wear wear unless it ingested debris from something disintegrating in the engine. Any wear on the end plate can be quickly removed by dressing the surface with some solvent wetted 220-400 paper on a flat surface, and the pump body end plate mounting surface and one gear can be so dressed as necessary to get end clearance down to two to three thou, which will help prime the pump quicker.
