Early 1972 Frame Stencil location ? - NCRS Discussion Boards
  • Kurt G.
    • April 30, 2005
    • 343
    Re: Early 1972 Frame Stencil location ?
    My car is the one Paul mentioned. I had a very difficult time finding the stencil location. I used the information provided by Quanta and was more confused. I pulled the rocker panel, got out the flashlight and went at it. After about 20 minutes I found what appeared to be part of the original stencil. Dug a little deeper and confirmed the stencil was located just under the aft portion of the passenger side door and the paint appeared to be white. So, I wiped off the stencil I sprayed on in a slightly different location and rolled anew one on. Although the frame is rough in texture the stencil looks pretty good. The car is a 9/13/71 build date with a frame build date of 8/23/71. Hope this helps.
    Kurt Geis
    Chairman, Midway USA Chapter
    Targa Blue 1972, Top Flight and Duntov Award, 2014
    Arctic White 1994, Top Flight, Hrt. of Amer. Reg. 2011
    Arctic White 2013 60th Anniv Special Edition Conv.
