There has been much discussion on this board about these headlamps. Be they plastic or glass, Wagner or Sylvania type.
There are guild lines in the respective Judging Manuals as to what is perceived to be correct.
The purpose of this survey is to solicit members to take a few minutes and look at their headlamps on their C4's, yes pull back the covers, its snowing here again also. Take a minute to help us out to fully determine the cutoff date of the switch from glass to plastic. The change date has been generally stated in the Judging Manual , but not fully documented to be between 1990 and 1991 from glass to plastic.
The reason given to me by others for the change over is that the weight of the glass bulb was causing the gears in the headlamp motor to fail.
That is not the issue here, but if anyone wants to chime in about the reason for the change over, please do.
I will take information from all the years from 1990 until 1996. What I request is the model year, ZR1 or other, build date, type-glass or plastic and manufacturer.
You can also email me at fulassoc@comcast.net
