Can someone tell me what the correct/original wheel cylinder numbers are for all 4 wheel cylinders on a 63? Every year for the last 3 years I've had one start to leak due to moisture buildup and eventually they rust then leak. I've decided to replace everything, lines, hoses, etc and switch over to Dot 5 so I'm trying to decide, do I get the old ones I saved (that might be original) sleaved with SS or Brass? or do I just buy new ones from the local auto parts store? I'm planning to have the car judged someday and I'd like to keep it as original as posssible but according to the judging manual the wheel cylinders are not judged and it doesn't look like the bleeder valves are either. the car might see 500 miles per year and I live in Ohio if that factors into your opinion. Looking for any advice on how to make the switch over from Dot 3 to Silicone Dot 5 too.
thanks so much
JF
thanks so much
JF
