pushing without starting C-6 - NCRS Discussion Boards
  • Richard L.
    • November 1, 1984
    • 191
    Is there a way to move a 2008 C-6 around the garage without starting it up? It's an automatic. If so, can someone provide step by step instructions.
    thanks
    Ric
    • 15573
    Re: pushing without starting C-6
    thanks
    Ric
    Is there something wrong with putting the gear shift in neutral and pushing it? I can do that with my 6-speed.
    • Richard L.
      • November 1, 1984
      • 191
      good morning Terry,
      I don't believe that my automatic will move out of park unless the engine is running.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        I do it all the time with my '07 Automatic in my garage if I have to move it by hand gettin' it lined up for the 2-post lift.
        -Make sure you're on level ground.......
        -Get in the car with your Fob.
        -Foot on brake.
        -Push lower portion of START button to put in ACC mode.
        -Shift to Neutral
        -Move car
        When done, put it back in Park by getting in the car again, foot on Brake, Shift back to Park, then hit ACC button to OFF.
        Rich
        p.s. BTW, to crank the Starter without actually starting the engine, on a Auto.....
        Set the E-Brake. Hold your foot on the accelerator pedal hard to the floor, then push the START button. Foot to floor disables the ignition, probably via a signal to the ECM.
        For a Manual, I never have done it, but I'd try it in Neutral as you may need the clutch pedal down too. Set the E-Brake too.
        • Tom H.
          • December 1, 1993
          • 3440
          If you hold the ACC mode for about 5 to 7 seconds, you can fool the car into thinking it is running. Even the HUD will work without the engine running if it has it !!
          Tom Hendricks
          Proud Member NCRS #23758
          NCM Founding Member # 1143
            • 15573
            good morning Terry,
            No kidding? I guess that shouldn't surprise me given that kind of stuff started with "put your foot on the brake before you can move from park" many many years ago.
            Cheer up. It gets worse. At the Hampton National last Summer the battery on the C7 went TU due to people continually opening the door to test the seating (see, there is an argument for disconnecting the battery when one is inside, except then the doors wouldn't open at all). I suggested to Tom Hill we just push it to the lift so us fanatics could see the underside of the car. That idea was/is a nonstarter. The C7 has electric steering and without a functioning battery the front wheels will not change direction.
            You have my sympathies in your frustration. I would be too.
            • Mike E.
              • June 24, 2012
              • 920
              Do the newer automatics squat when you dropped them in drive like the C3s did? For some reason I always thought that was kinda cool, it seems like the '84 I had did not. To be honest I can remember very little from the eighties.
              Mike
              • Thomas H.
                • August 31, 2005
                • 1053
                I'm sure that type of steering system has gone through tons of testing, but the thought of relying on software to control my steering on anything other then a video game makes me a bit nervous...........
                2007 Z06, Lemans Blue
                  • 15573
                  I sympathize with your anxiety, but the freight train is coming and we all had better get off the tracks.
                  Electronic throttle control has been with us for years (I am told at GM it started with trucks, of all things, before Corvettes got it.), and electric steering makes a lot of sense. I think on the C7 it technically it is electric assisted steering. There is still a mechanical connection between the steering wheel and the wheels. The wasted energy (fuel consumption) of the hydraulic power steering pump while the car is traveling down the road is overwhelming compared to the need for the hydraulic assist while parking. With the electric assist one only uses energy when it is needed. How long that heavy mechanical connection between the steering wheel and the front suspension remains is another matter. My thought is that the end is in sight, but we will have to see.
                    • 11608
                    IIRC, Mercedes has already tried it on a car.
                    • Tom H.
                      • December 1, 1993
                      • 3440
                      No kidding?That idea was/is a nonstarter. The C7 has electric steering and without a functioning battery the front wheels will not change direction.
                      Totally false. The car will steer, it just won't be powered steering. I push em around the showroom all the time.
                      Tom Hendricks
                        • 15573
                        Next time I see Tom Hill I'll tell him. I am only repeating what he told me at Hampton.
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11302
                          Tom, On the C6 with everything off if you switch the Park or Head lights on it lights up the DIC and shows the odometer mileage. Does that work on the C7 too?
                          • Bob H.
                            • July 31, 2000
                            • 789
                            If you are not driving it and you need to move it around on a regular basis, put it on dollies. Had to imprvise when I couldn't get my 67 transported prioe to leaving our second home. Thanks to using them, I have my 67 and a car in a single car garage
                            • Tom H.
                              • December 1, 1993
                              • 3440
                              Richard. Great question. I will answer it with a yes.............. and no. If you come up to a car that has been sitting and not started for a while. Say, a couple of hours. If you reach in through the window and turn on the parking lights, no odometer appears. If you start the car and then shut it down, the odometer will appear in the cluster when the parking lights are activated, but only for a minute or so, then the cluster will not react to the switch. On the other hand, the odometer always appears when the door is opened.
                              Tom Hendricks
