Do the vent ducts on the picture look like they are correct for a 1963-67 Corvette - NCRS Discussion Boards
  • Claus S.
    • December 30, 2010
    • 414
    Does this left hand side and right hand side AC under dash vents look like original ones for a C2 or are these ducts not original ones like i think and not original ones at all
    Does the 7 blade fan look correct for a 1963-67 factory AC car?
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Do the vent ducts on the picture look like they are correct for a 1963-67 Corvett
    The vent is certainly not correct.
    • Claus S.
      • December 30, 2010
      • 414
      Just what i thought because i think the ducts for a C2 are round/circular from the heater box to the ends
      • Mike G.
        • January 1, 1991
        • 418
        Roger: actually the vents are more of a "D" cross section shape most of their length. On the fan, that's not close either. Take a look at Long Island Corvette's #24-29B fan, which is the general look you want. Mike
        • Claus S.
          • December 30, 2010
          • 414
          I will not buy any of the parts above. Thanks Wayne and Mark
          This is how the correct parts should look like
          • Harry S.
            • July 31, 2002
            • 5258
            Claus, I know your car is a 64. Just an FYI.....
            The duct work on a 63 is not black it has a dark green tint. The best color I could used to describe it is olive-drab. I have never seen 63 ducts for sale, they are ultra rare. Also, no 63 AC car came with a 7 blade fan.
            • Claus S.
              • December 30, 2010
              • 414
              Harry i thought the late 63 had a 7 blade fan. I think Nolan Adams Volume 2 says so but i will have to check
              • Harry S.
                • July 31, 2002
                • 5258
                It does say that but best anyone can tell not one of the 278 (228 coupes, 50 convertibles) 63 A/C cars were delivered with one.
                • Claus S.
                  • December 30, 2010
                  • 414
                  Harry have you seen the 7 blade fan that LIC sells? I am thinking of buying one for my car?
                  • Harry S.
                    • July 31, 2002
                    • 5258
                    Sorry, no I have not seen it.
                    • Claus S.
                      • December 30, 2010
                      • 414
                      Have any here seen an evaporator lid with the tab/bracket(marked with a red arrow)that is on this evaporator lid on the outer AC box for a 1963-67 Corvette?
                      This is where the STV valve bracket sits
                      I wonder if this is either for a 1963 or 1967 only and if not it must be homemade
                      The bracket on the outer AC housing looks almost like a bracket for the expansion valve so this can not be original?
                      • Joe R.
                        • July 31, 1976
                        • 4547
                        Claus,
                        The ducts in the first picture are an aftermarket company selling a hang on air setup. The second picture of the ducts are good reproductions of 63-67 AC ducts made from fiberglass.
                        The below pics are AC boxes from a 63 and then a 64-57 box.
                        Good luck finding the correct pieces needed for a 64 AC.
                        • Claus S.
                          • December 30, 2010
                          • 414
                          Thanks Joe
                          The price for the few outer AC evap, heather box i have seen for sale is pretty high
                          I suppose they can ask whatever they want for the outer assembly since if any needs it they have to buy original parts
                          I know how difficult it is to get hold of these parts(some owner before me had cut the outer evap, heather box in half)since i looked for the outer AC evap, heather box for many, many years before i was so lucky to find one for my car
                          The first picture is of my restored outer AC evap, heather box for a 1963-67
                          Looking at the picture to the right, is the evaporator lid for a 1963 only because of the location of the STV valve bracket location?
                          Can any here post a picture of how the 1963 STV valve is mounted on the evap lid/box?
                          • Claus S.
                            • December 30, 2010
                            • 414
                            On the picture to the right is a picture of my restored STV valve for my 1964.
                            The picture in the middle is of the outer AC box for a 1963(see the bracket and nuts and bolt on the evaporator housing for the STV valve)
                            On the picture furthest to the right is a picture of a outer AC box for a 1963 with what i think must be a POA valve for a 1967.
                            Am i right about the POA valve on the last picture?
                            • Joe R.
                              • July 31, 1976
                              • 4547
                              Claus,
                              The picture on the far right is indeed a POA valve for a 67. The 67 valve was crimp sealed and left no way to rebuild the valve after a failure of the piston.
                              JR
