1959 Corvette - engine id, NOM - NCRS Discussion Boards
  • Robert C.
    • December 1, 2005
    • 164
    Folks,
    A friend bought a 1959 Corvette - original engine is long gone.
    We have a 283 pass car block with 1962 heads, intake, carb, generator, distributor, etc.
    Cleaning the car, we noticed it has the high rpm tach (redlines at 6500).
    We know it wasn't a fuelie - but we'd be interested to know if it was a dual quad motor.
    I started reading Nolan's book - need some tips.
    The other gauges appear to have the right needle shape........haven't pulled the tach yet.
    Any other tricks to determine what this was ?
    Rear axle was noted in a '58 post.
    Thanks in advance
    Bob
  • Nicholas L.
    • November 1, 1982
    • 340
    Re: 1959 Corvette - engine id, NOM
    The 270HP dual quad engine also has the 6500 RPM tach.
    • William C.
      • May 31, 1975
      • 6037
      need to see if the back of the tach is ink stamped "reads cable speed" or "reads twice cable speed" to figure if 270 or FI
      Bill Clupper #618
      • Robert C.
        • December 1, 2005
        • 164
        I can see one ink stamp with an inspection camera.
        p/n 1589102 ? Some of the ink has smeared......
        Where is the msg. stamped ? Side of case I think I remember from Nolan's book ??
        • William C.
          • May 31, 1975
          • 6037
          Part number for the tach on a 270 hp was 1549041, ink stamped on the outside of the case, with 6000 redline (approx)
          Bill Clupper #618
          • Robert C.
            • December 1, 2005
            • 164
            Thanks Bill - I'll try and get a better look at this tomorrow
            • Steven B.
              • June 30, 1982
              • 3976
              If no tell tale signs of FI (air cleaner/hose mounting, FI emblem holes patched, etc.) then a 270.
              • Robert C.
                • December 1, 2005
                • 164
                That was the first thing I looked for (AC mounting). w/w bracket is on the drivers side.
                Rear axle is original, came back as a 3:70 (4 speed car).
