I recently replaced my old fan belts with Quantas. I have a 69, L36 with A/C and P/S, but the A/C compressor is out at the moment as is the AIR pump. I believe the three remaining belts are properly tensioned and aligned, but there is an annoying noise at idle. This is NOT a "squeal" that might occur when revving the engine nor a PS squeal when turning the wheel. Engine temp doesn't make any difference. It's difficult to describe the sound, but it's not a high frequency period squeak. More like loud white noise. Normal engine noise covers up the belt noise when driving.
Because it was easy to do, I removed the alternator belt to see if the noise went away or diminished. It might have diminished slightly, but not much. I thought I'd check with you guys before removing the PS belt. Of course this method isn't an option for the WP belt.
I found only one post on this topic in this forum. The suggestion was to spray the belt with silicone spray. This sounds counter-productive. A tech-tip on another Vette forum suggested "deglazing" the pulleys by buffing the groove with a Scotch Brite pad.
Any suggestions?
Mike
Any suggestions?
Mike
