'65 Headlight assemblies, easier movement? - NCRS Discussion Boards
  • Michael J.
    • January 27, 2009
    • 7073
    Does anyone know about putting a spacer/washer on the shaft of the headlights to get easier, smoother movement? I seem to remember that trick someplace but can't recall any details. Any help appreciated.
  • Bill W.
    • November 1, 1977
    • 402
    Re: '65 Headlight assemblies, easier movement?
    Mike,
    Shouldn't be necessary. Those buckets are meant to swing with VERY little effort. If yours don't it's time for a little R&R. Before you get too deep into this have you removed either/both motors? They come out quickly once the hood it off. With motor out if any effort is required to swivel the bucket it's time to get your shop manuel out. Good news is all parts that may be worn are available. Back to the garage! Bill
    • Michael J.
      • January 27, 2009
      • 7073
      Thanks Bill. I also contacted Rick (who did the seminar on this at our chapter meet a few months ago) and he said the washers would go between the electric motors' gear housings. He is going to show me at his shop next week. Cheers and Merry Christmas!
      • Wayne W.
        • April 30, 1982
        • 3605
        They should spin easily if the balls are free. There is nothing there to resist movement. However, I have had some trouble with the new end rubber seals and the felt washers. They tend to squeeze the shafts.
          • 6940
          Mike, with the motors out of car the buckets should just flop in the breeze. If the motors drive gears grease has gotten hard the motors will have to work to open and close.I did my 63 motors and used a syth. type grease which will not harden over the years. my headlight open and close nearly the same speed, no mods.
          • Michael J.
            • January 27, 2009
            • 7073
            Thanks for the tips guys. I was having trouble with the side pre-load binding on the big drive gear on one side.
            • Daniel Y.
              • September 30, 2002
              • 185
              if you have someone hold the hood straight up, you can get the motor past the hood. if you manually turn the motor a little, they come out very easily. there is a plastic bushing but no washers. as the other gents have said. the buckets should swing freely.
              Dan Young
              65, 67 Duntov x2
              66 bowtie x 2
              71 LT1 TF
              90 ZR1 McCelland
              03 Anniverary
              06 Z06
