1970 LT1 alternator 1100884, is this correct, with ford pully? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    Just found another alternator, is this the correct pully?
    I have attached pictures of what I believe is the correct alternator for a 1970 LT1, but the ford pulley confuses me?
    Delco Remy 1100 884 61A
    OD 17 12V Neg. with NT stamped in ink,,,what do I have?
  • Edward J.
    • September 15, 2008
    • 6940
    Re: 1970 LT1 alternator 1100884, is this correct, with ford pully?
    Bill, I looked at the JM for 70/72 it states the NT code is for the 70 LT1 engine and for a A/C corvette also. as for the pulley it is generally a stamped steel pulley. As far as the ford part no. that is something I have never seen and suspect that it was installed possibly by a rebuilder at some point in its life.
    • Paul O.
      • August 31, 1990
      • 1716
      Bill
      The pulley for an LT-1 should be made from a solid block machine cut and silver plated single belt groove not stamped steel. Also check the rear case and see if the are I think 7 cooling fins built into the case.
        • 43193
        [ATTACH=CONFIG]49832[/ATTACH]
        [ATTACH=CONFIG]49829[/ATTACH][ATTACH=CONFIG]49830[/ATTACH][ATTACH=CONFIG]49831[/ATTACH]
        William-------
        This is absolutely not a correct pulley. Not only does it have a Ford part number but it's a 2 groove pulley and NO 2 groove alternator pulley was EVER used on ANY 1962-82 Corvette.
        As Paul mentions, please post a photo of the rear case and we'll be able to tell you if the alternator is completely correct.
        Addendum: This is what a correct rear alternator case for your application looks like:
        • David L.
          • July 31, 1980
          • 3310
          Bill,
          The pulley stamped "C9AF-10A 352-B" was first issued by Ford in 1969 ("C9" = 1969). The pulley appears to be correct for a 1969-1970 Mustang based on searching the web.
          Dave
          • William B.
            • April 30, 1975
            • 939
            Joe, Picture of the back side, looks to be correct for a 1970 LT1 or with A/C? But remove pulley
              • 43193
              [ATTACH=CONFIG]49846[/ATTACH]
              William------
              Yes, it's correct. So, you have a complete, very-difficult-to-find alternator with an incorrect pulley. That's a lot better than having an incorrect alternator with a correct pulley. In this case, the pulley is, by far, the easy part to obtain.
              • William B.
                • April 30, 1975
                • 939
                Thank you everyone, do not need this, I think its time try our new NCRS for sale site
                • Kenneth B.
                  • August 31, 1984
                  • 2084
                  Sent you a PM KEN
