I'm close to purchasing a '67 Coupe I recently discovered. It is an L79 with M21, 3.70 posi, TI Ignition, A/C, PW, off road exhaust and Headrests. Its a one owner car with only 53K on the odometer. Lots of documentation including Protect-O-Plate window sticker and maintenance records. It is an untouched, un-restored, matching number car.
The car has been stored since 1976 when it was parked due to a slight front end collision which damaged the fiberglass nose. It will need brakes and typical mechanical things before it's roadworthy. Not a problem. I'm concerned with the front damage and recently visited 2 Vette repair shops in my area and both quoted between $10K-15K to repair. The car has original paint. Both shops said they could get original laquer paint to match and paint just the nose. One shop suggested replacing just the few damaged panels (upper & lower nose and left front parking light panel) and the other said its better to replace the entire nose. It was not a hard hit and there is no frame damage. It will also need a new grille.
The engine has been maintained by oiling the cylinders and priming the oil system periodicly and spinning the crank by hand. However, the engine has not been started since the 1970's. The A/C system is still holding a charge.
The asking price is $40K which seems high due to the body damage. Looking for opinions on whether the price is in line with the market and feedback on repairing the fiberglass and paint. I would like to keep this car as original as possible. After repairs would this car still qualify as a "Survivor Class" car? What can or cannot be done if I wanted to keep it as a survivor? I'm new to the NCRS Corvette world but I did own a '64 roadster in the late 70's.
All feedback is greatly appreciated.
