Mid-Year conv upper window stop - NCRS Discussion Boards
  • Dennis M.
    Infrequent User
    • November 1, 1999
    • 6
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Mid-Year conv upper window stop
    Dennis,
    The upper window stops (rubber) attach to the same phillips screw that attaches the upper window channel felt assembly. The screw goes into the pot metal vent window frame as it's tapped for that small screw. There is a metal tab on the upper window channel.
    Hope this helps as I'm not sure we're talking about the same thing.
    JR
      Dennis -
      You won't see that upper glass stop or its attaching screw in the A.I.M., as the die-cast ventilator assembly arrived at St. Louis as a complete assembly, including the vent window and upper glass stop, ready to install in the door. There's no anchor nut for that phillips screw - just a tapped hole in the die casting.
