repro 66 dash face available-- can't find one - NCRS Discussion Boards
  • Stephen W.
    • June 30, 2013
    • 50
    '66 L79 vert #1241-- My dash guage cluster face needs repainted. I was thinking why not replace with repro to get better lettering cosmetics (i.e., "ignition", etc. lettering), but I can't find a vendor that makes this. If there is one, does it appear OEM for judging?
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: repro 66 dash face available-- can't find one
    Stephen,
    It's only my opinion but I would try and keep all the original parts and if the budget can bear it have the dash restored. The early L-79's have a lower tach redline than the later 65 cars so keep this in mind.
    • Stephen W.
      • June 30, 2013
      • 50
      Thanks-- it's only the dash face (fascia) I'm considering-- guages all restored already, would be reused as is. What I'm comparing is the cost to disassemble/ repaint/ reassemble original with worn lettering vs disassemble/ replace with new repro/ reassemble with crisp lettering, assuming a quality repro exists.
      • Timothy B.
        • April 30, 1983
        • 5177
        Stephen,
        I am not sure a reproduction part exists, I will say that there is always something different about reproduction parts so keeping the original is always the sure thing.
        • Mike E.
          • June 24, 2012
          • 920
          By worn lettering you mean the chrome is worn down or the actual lettering is worn? I believe it can be re-plated by someone that is good at plating pot metal.
          Mike
          • Stephen W.
            • June 30, 2013
            • 50
            Thanks-- Yes, lettering (prob original) is both aged/ worn and thin on plating-- I'm being convinced here that restoring my original is the correct thing to do, and I hope I can find the right restorer-- I seem to remember Eckler's has a restoration service.
            • Ken A.
              • July 31, 1986
              • 929
              The casting has never been reproduced & never will. Contact someone like Joe Ray if you want yours restored.
              • Mike E.
                • June 24, 2012
                • 920
                I would check in Driveline first then ask a few folks on here for references. If your removing the cluster yourself read these articles by John Hinckley.
                http://www.lbfun.com/warehouse/tech_...ster%20pt1.pdf
                http://www.lbfun.com/warehouse/tech_...ster%20pt2.pdf
                Mike
                  • 11608
                  Agreed. He did a 66 cluster for me, turned out beautiful.
