TH 400 differences between sbc and bb - NCRS Discussion Boards
  • Michael H.
    • January 29, 2008
    • 7477
    Re: TH 400 differences between sbc and bb
    Forward clutch count.
    • Michael H.
      • January 29, 2008
      • 7477
      Intermediate Clutch count. (2nd gear)
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Direct clutch count.
        • Michael H.
          • January 29, 2008
          • 7477
          #19
          As seen in the clutch plate chart, there's an almost endless number of different combinations of clutch plates. Some have several waved steel plates, others, just one, or none.
          The wave plates cushion the clutch application which results in a smoother shift from one speed to the next. Luxury passenger cars typically have more wave plates than performance cars, and the same is true for cars with larger engines/more HP.
          If a clutch pack (and other related items) designed for a Cadillac is used in a muscle car, the added torque will cause a slow clutch apply or overspeed during the gear change and this will eventually burn the clutch plates.
          I would be very surprised if all/any of the part numbers are still available from GM. Some may be available under newer/changed part numbers though.
          To convert to the six disc direct clutch pack, a unique clutch drum piston is required. I doubt if it's available though.
          • Mike E.
            • June 24, 2012
            • 920
            #20
            Michael,
            If you want to email those files to mike.eby@acdnow.com I can turn them into a PDF and post them on my server.
            Mike
            • Michael H.
              • January 29, 2008
              • 7477
              #21
              Originally posted by Mike Eby (55078)
              Michael,
              Mike
              Mike
              Files sent.
                #22
                Michael------
                Of the 10 clutch plates used for 1968-72 applications, 4 remain available under their original or supercessive part numbers and 6 are discontinued without supercession.
                • Dick W.
                  • 10483
                  #23
                  I would venture to guess that B&M would have any and all the clutches and other parts you would need
                  Dick Whittington
                    #24
                    Dick-----
                    I was referring only to the GM parts. Without a doubt these parts are available in the aftermarket, from B&M or otherwise. There are just too many of these transmissions out there for there not to be replacement parts from some source.
                    • Mike E.
                      • June 24, 2012
                      • 920
                      #25
                      Mike
                      Files sent.
                      PDF Version here.
                      In Adobe Acrobat use Shift-Ctrl + or Shift-Ctrl - to rotate page.
                      Mike
                        • 15573
                        #26
                        PDF Version here.
                        Mike
                        When I do Shft-Ctrl - or Shft-Ctrl + the image gets smaller or larger. I suppose it has something to do with the version of Acrobat I have (free) or I would rather blame Bill Gates and his cursed Windows 8.1. However, I found at the right of the Acrobat toolbar is the icon >>. A left click there reveals a drop down box with rotate options as well as 'got to top' and 'go to bottom' options.
                        Thanks Mike E for hosting these. I have saved them to my computer thus making them far easier for me to find than the book Mike H got them from. At least until this box bites the big one.
                        • Kenneth B.
                          • August 31, 1984
                          • 2084
                          #27
                          Originally posted by Ray Kimminau (8917)
                          Michael,Yes, the "CY" transmission was used with '69 L-88, L-89, L-71, and the Camaro / Chevelle / Nova 396 /375 HP .
                          I had on in my 1969 Camaro 375 HP conv. It was unbelievable. It shifted with a bang like a 4 speed. I loved it & I am a 4-speed guy
                            • 15573
                            #28
                            Michael,
                            What transmission was in the 1970 Camaro L1 Automatic?
                            • Kenneth B.
                              • August 31, 1984
                              • 2084
                              #29
                              It was the CY version. Book lists M40 base as a 237.60 cost & when ordered with the Z-28 it was a cost of 306.25 so I assume it was the heave duty.
                              • Michael H.
                                • January 29, 2008
                                • 7477
                                #30
                                Mike
                                Files sent.
                                Thanks Mike
                                The charts are much easier to read now. The pages make it a lot easier to understand than the GM parts book.
                                Trying to sort through the GM parts book for TH400 clutch plates was always very confusing for everyone.
