help a little confused - NCRS Discussion Boards
  • Kevin M.
    • September 19, 2013
    • 72
    My 1958 powerglide automatic (now a 350 turbo) didn't come with a heater.
    below is a picture of the 350 turbo transmission cooling lines on the passengers side inner fender.
    Are these clamps that are holding the hoses to the inner fender something that a past owner added
    or are they heater hose clamps?
    If they are heater hose clamps should they be on a non heater equipped car?
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: help a little confused
    A 58 Powerglide did not have a transmission cooler.
    Therefore everything coming out of the 350 transmission was added by the installer.
    I did one and just ran copper lines under the engine up to in front of the radiator and then to a small trans cooler.
    The lowest hole (not being used) is for the fresh air hose bracket. Not sure if hole is on heater delete cars but most likely it was.
    • Kevin M.
      • 72
      Bruce
      Thanks for the reply. I think I'll do the same and run some new lines just to get rid of the big black hoses.
      Did a search on line and I see that same hole on other car that were not equipped with a heater.
