timing cover 1959 - NCRS Discussion Boards
timing cover 1959
  • James W.
    • January 11, 2014
    • 8
    timing cover 1959
    I wanted to know if a reproduction timing cover will pass inspection or should i try to buy an original ? 1959 Thanks for any help ( I tryed to look it up but could find nothing)
  • Philip P.
    • February 28, 2011
    • 558
    Re: timing cover 1959
    James I believe the difference is the timing tab. I can not seem to get the picture viewer to work. Basically the tab has a O and A and the degree lines, some of the newer have the lines marked in the degrees.
    I'll try t figure out the photo problem an try to post it.
    Phil
    • James W.
      • January 11, 2014
      • 8
      Philip, thanks for the reply-Jimmy
      • Philip P.
        • February 28, 2011
        • 558
        If you need one let me know .
        Phil
        • James W.
          • January 11, 2014
          • 8
          Phil, Paragon has them & they seem correct. I am open for whatever option would be best. What do u think?
          • Philip P.
            • February 28, 2011
            • 558
            If you want to send me an e-mail pkporter@q.com I will send you a photo of the one I have, you can have it for my cost ($10) plus shipping. I pick things like this up as swap meets just incase. Sorry I have not got the photo insert to work.
            Phil
