I'm having issues with the reproduction Wiper Ground wires from LL and M&H. They supply a wire which is 14 3/4" long, and is too short to reach safely between the wiper motor mount screw and the right inner rear valve cover screw.
The GM part# is 3733145. It is also used for the '55-'57, however those attach to the cowl brace screw, IMO closer to the motor.
Is there a wire length spec for the 3733145 in anyone's possession? I found no help in my '29-'59 P&A Catalog.
Does anyone else have problems with these reproduction wire lengths? On the '58-'62's it seems it needs to be a few inches longer to keep clear of the hot ballast resistor and far enough under the ignition shielding on radio equipped cars.
Rich
Rich
FYI, the 58-62 repro(and maybe the original) Radio Ground wire is actually, IMO, a bit too long. I've used the repros before and I have to tuck the slack inside the firewall area.
