Re: Converting to Silicone Brake Fluid
John,
Several decades ago, when I got three or four SAE papers from them, the one that sticks in my mind contained an examination of several systems that were introduced to DO5 in the manner you reference. Those were military vehicles that were subsequently stored in Panama. A dark sludge (for want of a better term) formed inside the brake system, and the researchers concluded this was as a result of the lack of complete removal of the polyglychol fluid. They noted that the sludge appeared to be harmless, however. I am not sure if that is the paper you have.
The label on the cans of Dow DOT5 that I have from many decades ago actually recommend flushing the DOT5 through the system as a means of removing the polyglychol fluid.
I chose not to use that method, but my system was already more than partially disassembled, so the choice was easier.
John,
