I recently purchased a 1964 coupe that was delivered without seat belts. I plan on purchasing them and installing them myself. My question is how and where do you anchor them? Thanks Ron T.
64 Vette seat belt installation
Re: 64 Vette seat belt installation
Your 64 was originally delivered with seat belts. The mounting brackets are installed on each side of the seat rear. Just get the four bolts and screw them in. You need not take the seats out just slide them forward.
Purchase a copy of the 64 AIM.
- Top
Thanks for the info Harry but I don't see any mounting brackets. The seats were recovered so it's possible the brackets were covered over. Could you be more specific on where the brackets are located? Thanks again. Ron- Top
I had the same problem with my 1963 Corvette, the previous owner probably had taken out the seat belts. I was able to locate the holes and reinstalled original seat belts.Attached Files- Top
Thanks for the reply Ruedi. Could you tell me how you were able to put a bolt in the door sides ?There is very little room. Also I don't see any holes for the belts to go thru the floor.- Top
Look under the car, can you see the two required brackets required for each seat? Post pictures of the inside and under the car.
The four of them will look like this------> http://www.parts123.com/parts123/yb....5AAHSV~Z5Z5Z51
The four bolts will look like this-----> http://www.parts123.com/parts123/yb....5AAGVF~Z5Z5Z51
- Top
Ron, If your brackets are missing in action The outboard one that closest to the frame side is really not accessible with the body on the car. and they are riveted to the body, The inboard ones can be installed on the car. The problems with those brackets were after 50 years the bolts broke or the weld nuts broke free and just spun the retainer bolt, Next step after that was to cut the bolt heads off and drill the rest of broken bolt out. and also the rivets tend to fall rot and the brackets fell out. Hopefully the brackets are still there under the fiberglass.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Hi Ed, The brackets look new with nuts welded on but the door sides look impossible to reach to install a bolt and I don't see any holes in floor on either side to push the belts thru.Ron, If your brackets are missing in action The outboard one that closest to the frame side is really not accessible with the body on the car. and they are riveted to the body, The inboard ones can be installed on the car. The problems with those brackets were after 50 years the bolts broke or the weld nuts broke free and just spun the retainer bolt, Next step after that was to cut the bolt heads off and drill the rest of broken bolt out. and also the rivets tend to fall rot and the brackets fell out. Hopefully the brackets are still there under the fiberglass.- Top
I am replacing belts on my '64 roadsters. Outboard bolts were so rusted, wouldn't budge, hex heads stripped so have to drill + tap. Anyone have this experience? Thanks. Mike- Top
