Does anyone have a source for a correct radiator for a 1982? The usual suspects such as DeWitts, Paragon, Corvette Central, etc, all come up with aluminum replacement
1982 Radiator
Re: 1982 Radiator
Mike-----
What you're looking for is a GM #3053440. It was discontinued without supercession in July, 1994. So, it's been gone almost 20 years now.
What's wrong with your existing radiator? Is it not original? If original, why couldn't it be re-cored?In Appreciation of John Hinckley- Top
Re: 1982 Radiator
Believe it was available through AC Delco sometime after that. Don't have the old catalogs anymore, but I seem to remember purchasing a few in the last '90'sDick Whittington- Top
Re: 1982 Radiator
Mike-----
If the tanks are in good shape, a re-core is, functionally, virtually as good as a new radiator-----maybe even better from the point of originality. That's because SERVICE radiators, depending upon when manufactured, may differ in minor ways from the originals, especially as it relates to the tanks.In Appreciation of John Hinckley- Top
Re: 1982 Radiator
Mike, My original owner 1970's radiator is original and still doing the cooling. It has been removed and cleaned by a radiator shop at least once and leaks repaired a couple of times. Still has the original core. Have you taken your 82's radiator to a radiator shop for an estimate for cleaning?- Top
Re: 1982 Radiator
In one of my prior lives, among other ventures, I owned a radiator repair shop. The radiators of the mid seventies to sometimes in the eighties (nineties) were not of the same quality as the earlier units. It is my belief that either the tubes were either thinner or made of a different composition. It was not unusual to see a five year old core have so many leaks that they were not worth repairing. Also the tank seams were bad to split.Mike-----
If the tanks are in good shape, a re-core is, functionally, virtually as good as a new radiator-----maybe even better from the point of originality. That's because SERVICE radiators, depending upon when manufactured, may differ in minor ways from the originals, especially as it relates to the tanks.Dick Whittington- Top
