70 4 speed interlock cable routing - NCRS Discussion Boards
  • Bill L.
    • February 1, 2004
    • 1403
    I have the AIM and it shows how to rout the cable. It just seems really close the the clutch fork. (Above the clutch fork) Do I need to manipulate the cable bend for more clearance?
    Does this sound about right? Does someone have a picture from underneath showing the routing past the bell housing and around the clutch fork? (May be tough to get a picture I know)
    Mine did not have a cable when purchased. As a result I have no reference.
    Bill
    Re: 70 4 speed interlock cable routing
    Bill
    Bill------
    It does run pretty close to the clutch fork. Attached are photos from a 1969 but I believe it's the same as 1970.
      Bill------
      Joe -
      Nice-looking core shake-out plugs .
      • Bill L.
        • February 1, 2004
        • 1403
        Bill------
        [ATTACH=CONFIG]50650[/ATTACH][ATTACH=CONFIG]50651[/ATTACH][ATTACH=CONFIG]50652[/ATTACH]
        Thank you Joe.
        That is exactly what I had. It just seemed maybe it was too close to the fork.
        I will continue with the reassembly.
        Bill
          Joe -
          John-----
          They're just absolutely DIVINE! They give me pleasure every time I see them.
            Thank you Joe.
            Bill
            Bill------
            By the way, although the "Mickey-Mouse" clip is not installed, the flange on the cable is fully seated against the bracket. So, the position of the cable is the final, installed position.
