I was wondering when the Corvette first was produced being the first real production car whos bodies were fiberglass how were body repairs handled? Did Chevrolet have service bullitins on repairing fiberglass? I remember one of our shop teachers had a 61 and ran into something and all us kids were amazed to see a fender actually crack. Body shops had no experience with fiberglass repair since all cars were steel. What did they do just replace whole fenders and doors?
Fiberglass repair in the begining
Re: Fiberglass repair in the begining
my car was hit hard in the RF in the late 50's - the gap between the OE fender and replacement was filled with resin and backed with ckicken wire......
the hood corner - where the hood hinge was repaired - they used a tube sock as backing....
I still have the tube sock.....
I see tack....wood screws...pop rivets.....1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
1957 Corvette - FI 3 sp - Black and Silver- Top
There is a portion of the ST-12 (page 1-48)that deals with the repair process that was to be used for C1 corvettes. In my early life I worked at a boat repair/building company and that was one of the task we did for a local Chevrolet Dealer (Appleway in Spokane, Wa). I can remember grinding the cracks/breaks of paint and we did what we needed to get panels back to shape. The one thing that the owner did not like to use fiberglas cloth as he said it would eventually show in the surface, we would fill with mat material and do final work with body filler. We also were not allowed to leave anything that we used for molding in the car I can remember removing chicken wire and cardboard as was mentioned on cars with previous repairs. I just repaired a set of kick panels for our 1960 using the same procedures even made a couple of small molds for the areas that were missing.
Phil- Top
Interesting repair, we would make a backing and screw it to the area and lay in glass and once set would remove the screws and what ever else was used. Normally both sides of the break was glassed if you could get to it. The front portion would have the breaks ground out and new glass laid in then sanded down and finished. The back sides were cleaned up some but in looking back they were not given lots of attention.
PhilAttached Files- Top
We would use aluminum strips on the outside pop rivited to the panel to hold it's shape, then use mat on the prepared back to give it it's strength.
Then drill out the rivets, V the cracks and fill them.
DOM- Top
I have receipts from a body shop in Washington state that worked on my 62 back in the early 70s. not sure if they did this particular "repair" of the trunk latch but this was apparently done because of a crack in the latch support face and it was broken loose from the rear panel. as you can see, the bondo was over 1/2" thick and covering the screws that held in the latch mechanism. nice! I also found various pieces of aluminum riveted in under a mass of fiberglass "cotton candy" in the rear right corner and tail light area.
- Top
