Re: roller cam in my 75 roadster
Ross, my 1968 L79 has 97,421 miles on it now. It will be 46 years old this month. The engine still has it's original pistons, rings, valves, camshaft and lifters. The engine has not been apart for engine work. New clutch pressure plate about 41 years ago. Runs very good, still really enjoy the acceleration in first, second, and third gear. Your 1975 has low miles if the odometer has the correct mileage, my 1970 had 160,000 miles on it when I removed the engine to install a GM higher horsepower crate engine in 1992. My 70's 350/300 engine was running fine when it was removed, I still have it and would reinstall it if I had to. I agree with the posters who do not recommend a rebuild for your 1975's engine. I use the 10W40 diesel type oil in my cars for the ZDDP protection that no longer comes in other automotive oils to protect the flat tappet cam and lifter cars. The oil in my cars engines stays really clean looking a lot longer in using the no-lead gasoline.
Interested in what others have to say about helping clean a dirty engine. A long time ago a person told me he was using one quart of transmission fluid at the oil change and changing the oil again when it showed dirty oil.
