67 Turn Signal switch - NCRS Discussion Boards
    Re: 67 Turn Signal switch
    Originally posted by Tim Gilmore (16887)
    I tried to order one from Paragon last week, they've been on back order since August of 2012......
    Tim -
    Have you tried "Shee-Mar" ?
    • Tim G.
      • March 1, 1990
      • 1358
      I have not, but I will. Thank you, John.
      • Paul Y.
        • September 30, 1982
        • 570
        #18
        Tim -Have you tried "Shee-Mar" ?
        I have had great luck with Shee- Mar as they are just up the road from me and seem to make quality parts. Never had to bring a problem back to them so don't know how they respond to that but they are very helpful to multiple questions.
        It's a good life!
        • Ron C.
          • January 2, 2012
          • 21
          #19
          Tracked down the problem to the turn signal switch. Does anyone have a recommendation/preference of opinion on who makes a better more accurate switch:
          Shee-mar or Lectric Limited?
          • Tim G.
            • March 1, 1990
            • 1358
            #20
            Shee-Mar is on back order eight weeks, I don't know if Lectric Limited has the part either. Paragon has had it on back order for some time now.
            • Ron C.
              • January 2, 2012
              • 21
              #21
              Is there a deduction for repro turn signal switches...assuming the wiring harness is the only part you see? Thx
              • Stephen L.
                • May 31, 1984
                • 3148
                #22
                The wire colors are different (brighter). If a judge looks, it is evident. I know they look at the plug and attachment to the steering brace.
                If you are good with a soldering iron, you can transfer the wiring to the SHEE-MAR switch. A minimum would be to transfer the plug housing. Original are black while aftermarket are brown. You could also reuse the good part of the original switch if salvageable, combining the switches.
                • Ron C.
                  • January 2, 2012
                  • 21
                  #23
                  Stephen,
                  That's a huge help...much appreciated.
