67 ash tray - NCRS Discussion Boards
67 ash tray
  • Randy R.
    • March 1, 1983
    • 477
    67 ash tray
    My ash tray won't come out. Interference with the console. Manual says owner remove prior to judging. Suggestions? Randy
  • Marco H.
    • March 1, 2002
    • 218
    Re: 67 ash tray
    Remove your console and take out the ash tray. Make sure it is an original or a better reproduction. Check, that there is no interference that prevents the slider door from opening all the way. Reinstall the console and try to insert the ash tray. If it doesn't go in you will have to look at your console mounting. Sometimes repro dash pads prevent the console from sitting in its proper location.
    Hope this helps.
    Marco
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Re: 67 ash tray
      The rivets holding the flanged side tab are sticking out too far and hanging up it's removal. Had the same issue with a repro some time ago. Maybe your original has a similar problem, or if a repro, for sure......
      Yank it out with gloved fingers, grind down or file the rivets a bit, and it'll be fine.
      Rich
        • 6940
        Re: 67 ash tray
        Along with Rich's post add a touch of dilectric grease to tab, maybe this will help ease removel.
        • Michael H.
          • January 29, 2008
          • 7477
          Re: 67 ash tray
          There was a GM service bulletin about this issue in 67. (or 66?) The instructions simply stated "loosen all of the console retaining screws and, using an awl or similar tool in one of the screw holes, gently pry the console in the required direction to provide clearance to remove the ash tray.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            Re: 67 ash tray
            Ahhh, good info....I couldn't read back in '67 as I was only a toddler.
            I do recall the original in that '67 I tinkered with had it's original ashtray, and the owner wanted new. That repro was tougher to get out for sure, but the original struggled a bit too. I played around with the tray retainer after restoration of it and new screws after removing a few broken ones. That was fun. That repro had to be worked on a bit to get it out.
            A little silicone lube is a good idea. I should've tried that.
            Rich
            • Kenneth B.
              • August 31, 1984
              • 2084
              Re: 67 ash tray
              Don't think I had to take the ashtray out when I had my 67 judged. What is the reason it has to come out for judging?
              • Marco H.
                • March 1, 2002
                • 218
                Re: 67 ash tray
                There is a "AAC" stamp that the judges usually want to see.
                • Kenneth B.
                  • August 31, 1984
                  • 2084
                  Re: 67 ash tray
                  OK THANKS. I will see if my 2 67'S come out & if they have the AAV.
                  • Richard M.
                    Super Moderator
                    • August 31, 1988
                    • 11302
                    Re: 67 ash tray
                    Here you go.....
                    • Harry S.
                      • July 31, 2002
                      • 5258
                      Re: 67 ash tray
                      On a 63 it's a one year only ashtray, it has a single tang up till about VIN 19000.
                      • Marco H.
                        • March 1, 2002
                        • 218
                        Re: 67 ash tray
                        Harry, would you happen to have a picture of an early '63 ash tray?
                        • Harry S.
                          • July 31, 2002
                          • 5258
                          Re: 67 ash tray
                          Here ya go.............
                          • Marco H.
                            • March 1, 2002
                            • 218
                            Re: 67 ash tray
                            Thank you!!
                            • Randy R.
                              • March 1, 1983
                              • 477
                              Re: 67 ash tray
                              I will try this. Thank you, Randy
