Went to start up the 1960 yesterday and it was a no-go.
Engine turned over just fine but no start. There is fuel in the tank and fuel in the line to the fuel pump. Also fuel in the glass bowel to the 2x4 carbs. But no fuel in the carb when I pump the accelerator. What do you think, "Fuel pump"? Anyway to test this out before going thru the work of replacing the pump? I searched the archives and this does not look too easy (or too hard either - if you can control the push rod it would seem). Thanks for the advice.
Joe
Joe
