I have a GB light/switch which I think is the 3859327 as in the pic below (pic came from Jack Humphrey post). Mine came out of a 63 Corvair and has a black lead which I want to change and I want to clean up the metal face plate, so two questions on this part:
1. How do you get the face plate off the plastic housing? I've seen pics of them apart but don't see how they come apart.
2. How do you get the lead terminal out of the housing?
The other pic shows the same part plus the shield. I got this pic off this forum and think it is an original shield correct for mid years.
1. I have this or a similar shield (very thin material). When installed on a bulb the seam spread to about 3/16 inch. The pic shows it very close in an uninstalled mode. Does an original shield spread out significantly when installed?
2. It appears that the shield when installed is very close to the base of the bulb and is electrically hot or would be with any side pressure on the bulb (e.g., just bumping it). Has anyone found this to be an issue?
