I've owned a 64 Coupe (VIN #2474) since 1973. The attached picture shows the engine block pad when I purchased the car.
I'm hoping someone can help with the questions raised in that picture. Here's at bit more .... when I purchased the car it was set up as a 327/365, correct intake, Holley, air cleaner, camshaft, heads, balancer, idler, distributor, etc., here's some specifics on internals.
Vin #2474 .... approximate production date Oct 10, 1963,
Block .... casting 3782870, casting date .... A152, (std bore when I purchased),
Block Pad ID .... VIN # or VIN location defaced (see attached),
Block Pad ID .... engine assembly plant, date & suffix .... missing an engine assembly plant, remainder of ID .... 05I4RB, I guess the RB suffix translaets to a manual transmission passenger car from 62 thru 64,
Heads ..... casting 3782461, casting date .... I233,
Camshaft .... casting 3849347 (30/30 cam),
Pistons .... TRW 3866954, (std bore).
Questions,
- has anyone encountered a defaced engine pad before & what would be the reason(s),
- why a missing assembly plant,
- how does an accessories & internally correct 64 365 engine end up in 1962 block,
- I can imagine that the original engine was blown & rebuilt with the 62 block, but why deface VIN location & why no assembly plant ?
Any help / thoughts would be appreciated.
Jim
Questions,
Jim
