1967 Gauge cluster - Ammeter - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    Ammeter rear view. Original gauge has a third stud for holding into place, current repop (about 20 years old) is missing. Is the third stud required? The gauge does move even with both electrical connecting studs tight to cluster backing. See attached pix.
    How can I test the old gauge for function and set the gauge to ZERO. It is biased to a slight positive, and is nicely dampened. I can nudge it to either side and it will return to the slightly positive, or charging, indication.
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 1967 Gauge cluster - Ammeter
    Don O,
    The amp gauge does not need a ground so the stud was left off to reduce cost.
    Pull the pointer straight out holding it firmly. Then sero it and push it firmly in place.
    If you have a problem just send it to me and I'll do a freebie for you.
    JR
    • Donald O.
      • May 31, 1990
      • 1580
      Originally posted by Joe Ray (1011)
      Don O,
      JR
      Thanks Joe. appreciate the offer.
      How can I tell if the gauge is good? The original and the current resident of the cluster never moved very much, if at all, in either direction. I did check for voltage on both wires and both had 12.7 volts.
      Is there supposed to be a foam ring around the speedo or tach gauges? Any Southern vendor of said foam rings?
      DonO
      • Harry S.
        • July 31, 2002
        • 5258
        DonO
        Use a 1.5v battery. Hook up a set of alligator clips to the battery the best you can. Then just, for an instant, touch the gauge contacts. The gauge should respond if it's good. Then reverse polarity and touch again, the gauge should respond in the opposite direction.
        If the gauge does not respond it's DOA.
        I just took 3 clusters apart and never saw a foam ring? Not sure what you are refering to.
        • Enzo C.
          • January 12, 2012
          • 533
          Hello Joe, I have a jumping amp gauge.... but it doesn't do it always mostly at idle??? any ideas or thoughts??Thanks
          Enzo Colosimo
          Ncrs Ontario Chapter Chairman 🇨🇦
          ENZ-Z06/67
          • Joe R.
            • July 31, 1976
            • 4547
            Enzo,
            The amp gauges have a dampening fluid and as the gauges get old the fluid is lost. The magnetic dampening is lost as the fluid is lost so the pointer jumps when the gauge is shaken by bumps in the road or a rough idle.
            You need a new gauge.
            JR
            • Donald O.
              • May 31, 1990
              • 1580
              Here's a pix showing a ***** of the foam, I'm assuming its from a ring. DonO
              • Harry S.
                • July 31, 2002
                • 5258
                Don, it's not from a ring. There are 4 pieces of rubber on each of the large gauges and three maybe four on each of the small gauges. It is there to act as a cushion for the glass. A kit is available from most of the parts suppliers. If you only need the small pieces a black o-ring from the local hardware store can be used, just cut it into 7/8 sections.
                Here is the kit from LIC ----> http://www.parts123.com/parts123/yb....5AAGHT~Z5Z5Z51
                • Richard M.
                  Super Moderator
                  • August 31, 1988
                  • 11302
                  Here's where they go....
                  Both big and small lenses.
                  • Joe R.
                    • July 31, 1976
                    • 4547
                    Richard,
                    That's the correct kit for the lens and also included is the foam to go around the trip meter. The piece of foam that Don O is seeing came from the back of the trip meter. It's a small foam rubber piece that will crunch up after all these years. It was used to keep the light directed inside the instrument cluster. The foam strip can be cut from commercial foam but is not included in any kit that I know of presently.
                    JR
                    • Donald O.
                      • May 31, 1990
                      • 1580
                      what is the part number for the seal kit?
                      I suppose I could go Bubba and make something from some closed cell foam.
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        Zip has it is stock if LIC doesn't....
                        D-639 <--click this to see
                        Rich
                        p.s. JR, thanks for that info, but I can't picture the foam you're speaking of. Do you have any pics of original foam and exactly where it's placed?
                        • Joe R.
                          • July 31, 1976
                          • 4547
                          Rich,
                          Posting up the back side of the trip odometer shield. The foam is attached by the strip on the upper back of the shield. Sorry I don't have the foam but it crumbles as soon as it is touched.
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11302
                            Thanks JR, I never knew that. All these years I've missed that little critter. I see traces of the glue or tape on the meter cover of this '67 cluster.
                            Thanks for sharing that.
                            Rich
                            • Donald O.
                              • May 31, 1990
                              • 1580
                              1967 Gauge cluster - Update
                              The cluster is all apart, have new foam kit for cluster lenses and trip odometer, as well as a hardware kit of screws and nuts for the inner cluster panel that holds the lenses in place. but be for I start re-assembly I have a few questions.
                              I would like to repaint the inner cavity of the cluster in a light green. What color exactly and where could I get some?
                              The nuts that hold the inner cluster lens retainer in place were a gold toned or dichromic looking and the kit from LIC are nickel or tin plated silver looking. I know no one could ever see them but which is correct?
                              There is a piece of tape, about 2" wide that goes from the bottom of the gauge cavity up to the rim of the cavity and then down the outside the same distance. The tape is where the ignition switch is. It is painted the same light green as the inner surface ans is a faded white outside the cavity. Any ideas as to function, originality, etc?
                              If needed, I can go back into the shop and take some photos, which always provide a better description.
                              DonO
