1967 Gauge cluster - Ignition switch - NCRS Discussion Boards
  • Donald O.
    • May 31, 1990
    • 1580
    Does the lock nut on the panel face just screw off? Mine unscrews only a few threads and then stops. See Pix.
    I also found a small cardboard shield at bottom of light housing for the ignition switch. The orientation for re-installation is not known to me or even if it was there from GM as built. see pix. Comments please
    cardboard detail pix
    • 6940
    Re: 1967 Gauge cluster - Ignition switch
    Don, you will want to remove the lock cylinder first then the retainer. Put you key in a turn to first position and insert a paper clip into the 1/16 size hole and remove the cylinder with key installed. The card board piece is for the light bulb to light up the ignition cylinder hole where key inserts.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11302
      Edward, after inserting the paperclip in the hole and pushing in, you turn the key CCW from ACC position to remove the cylinder.
        • 6940
        Rich, Thanks for correcting me.
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Edward, I usually forget after a few months of non instrument work, but I just did a '67 cluster recently so I had it close in my brain.
            • 6940
            Rich I know what you mean.I seem to be having a lot of brain farts the older I get.
