I need to remove the tachometer on my 60' for service. Can the pod be removed to expose the tach without removing all of the wiring harness connections to the gages? In other words, I know both panel assy. need to be removed however, can this be done leaving the gages and speedometer in place?
C1 Tach removal
Tags: None
- Top
Re: C1 Tach removal
Speedometer has to come off the cluster before you can access the tachometer. No other way.
The least painful way to work on the tach, in my opinion, is to pull the cluster, set it on your bench, and then disassemble it.
Jim- Top
Re: C1 Tach removal
I agree with Jim L., pull the whole cluster.
First disconnect the battery.
I have found that you can release the 2 sets of gauges from the cluster and let them hang if you don't want to remove the wires from them.- Top
Re: C1 Tach removal
My thought was that it would take less time and trouble to just let the gauges hang. I am not excited about labeling each wire as it is being removed from the back of the instrument panel.- Top
Re: C1 Tach removal
I understand your concern.
However, when I R&Red my '60's cluster, I chose not to tag each little wire and it worked out fine. My reasoning was that the place to attach each wire is fairly obvious and, in fact, wire lengths are so critically manufactured that they simply won't reach much other than their intended terminals. IOW, it's really hard to connect something incorrectly.
Really, pull the cluster. It's easier that way.
Jim- Top
Re: C1 Tach removal
Use a digital camera to take pictures of where all the wires go. Then pull the entire cluster.
Tom1958, 283/245, White/red - Top Flight, October 2016
2007 Z06, Lemans Blue
Newsletter Editor, Delaware Valley Chapter- Top
