Hello once again,
I took a photo of my engine pad, just want to hear your opinions about it. It surely looks like a fake
(1963, 327/300HP).
I also found the block number being 782870, is that the right number for a 327/300 block in a 63 Corvette? I suspect that the original block must have been changed by a previous owner.
Additional question: On the second picture is a bracket which is connected to the firewall, it is chrome. Could someone please explain if this is original or what bracket was used in 1963? And how is it called, if I need to order one.
Thank you very much
(1963, 327/300HP).I also found the block number being 782870, is that the right number for a 327/300 block in a 63 Corvette? I suspect that the original block must have been changed by a previous owner.
Thank you very much
. That has to be someone's idea of matching numbers. I like it, its almost whimsical. The block could be original, but its definitely been decked and re-stamped.
