Hi all,
I have an 022 FI distributor and an 070 FI distributor. The 070 has been redone and I'd like to switch the p/n plates between the two. The only physical difference I can see is that the top part is oriented differently between them, so it looks like all I have to do is remove the clamp holding the upper and lower pieces together, break the two pieces apart at the gasket, and rotate. Any reason why this wouldn't work? But I don't know if there is something different with the gears, although I wouldn't think so.
Bob
Bob
