Looks like i really have the "Gas Gremlins". more gas smell in the garage and a gas puddle under the 67 small block. Gas line is OK but gas appears to be seeping out of the fuel pump, I think from where the top and bottom halves are joined together. So it looks like I have to either replace or "have replaced" the fuel pump. (did this when I was younger with my pontiac lemans 326 and remember much #@%^$&* but also remember that I needed the car the next morning - so working slow and stopping was not an option). I have read some of the posts on fuel pump replace and I have a few questions before I decide to either do it myself or have it done.
1. does anyone have a picture of how the pump rod looks inside the engine block - It would help me if I could visualize what I was trying to do as I position the pump. I notice some us "Grease" and some use a long "bolt" to hold things in place - but it would help me if I know what I was trying to hold in place with what?
2. I have attached a copy of a picture from the archives showing the front of the block with the two holes. I have also attached a copy of the front of my block - is the top hole on the archives picture the same as the hole with the bolt in it on my car and is that the bolt that is talked about using when replacing the fuel pump.
3. Do you think this can be done without removing the radiator hose?
4. It is suggested that I stop the engine at TDC - how do I do that?
Thanks for the help,
Joe
Joe
