Ralph's 70 LT-!
Re: Ralph's 70 LT-!
How many miles?Vice-Chairman (West), Michigan Chapter NCRS
Re: Ralph's 70 LT-!
Thanks Ralph and Alan. Love seeing those unrestored engine compartments. I really like that late '69 early '70- 2 piece distributor box.Larry
2002 Z51 Convertible
1969 L46 Convertible- Top
Re: Ralph's 70 LT-!
Actually the '69 shielding was 2 piece but the early '70 distributor shielding was 3 piece. From the picture it looks like that box is two piece, which was correct for a '69 but not for a '70 . You can tell by the two small screws on the passenger side of the box which are missing in the picture.
Edit: After further review, I zoomed in on the box and I believe that the holes for the screws are there, but the screws aren't attached. Also, when I say 3 piece I include the top as one of the pieces.
Thanks.- Top
Re: Ralph's 70 LT-!
Yes 3 pieces counting the lid. The 3 piece was used late '69 from at least September on through about mid '70.Larry
Re: Ralph's 70 LT-!
Ken,Actually the '69 shielding was 2 piece but the early '70 distributor shielding was 3 piece. From the picture it looks like that box is two piece, which was correct for a '69 but not for a '70 . You can tell by the two small screws on the passenger side of the box which are missing in the picture.
Thanks.
As you do the research on that 'feature' be sure to separate big block from small block.
Edit add:My 1970 SB #2161 has a three piece distributor shield. Ralph's car is later in the 6000 range IIRCTerry- Top
Re: Ralph's 70 LT-!
Terry-----
My original owner mid-September, 1969 built car had the 3 piece shield.In Appreciation of John Hinckley- Top
- Top
