63 borg warner tranny factory installation - NCRS Discussion Boards
  • Robert B.
    • March 1, 1992
    • 263
    Anyone know the sequence of manufacture and installation of the Borg Warner tranny's.
    What interest me is the time frames involved from the Borg Warner plant to the final installation at the assembly line. Casting of the main case ect. then assembly,then shipping to the corvette assembly plant,installation on to the rolling chassis. How long did all this take in normal day to day operations. Thanks Robert
  • Harry S.
    • July 31, 2002
    • 5258
    Re: 63 borg warner tranny factory installation
    This is my April car.
    Trans Build - WD231 or 4/2/63 first shift
    Maincase Casting T10D-1 B 22 63
    Tailhousing Casting T10-7D 1963
    Sidecover Casting T-10-148-B 1963
    Rear Bearing Retainer Casting T-10-107 1963
    Engine Build - 04/15
    Car Build - 04/20
      • 6940
      Harry what was the casting date on your apr. car?? do you recall? Thanks Ed
      • Harry S.
        • July 31, 2002
        • 5258
        Ed, I added it to my post.
          • 6940
          Thanks Harry.
          • Timothy B.
            • April 30, 1983
            • 5177
            I have a T-10 D case in my 63 coupe that does not have the 62 date cast into the side, it only has (K) then (22) but no (62), it's a early 63 car. I read somewhere that some D cases have this cast date without year, my case is not the original but I tried to find one as close as possible.
            Do I have a service replacement main case or are there others with main cases without the 62 or 63 cast in the side.
              • 6940
              Tim, All the 63 T10-D cases I have seen has a month-day-year casted in them and my understanding is the T-10D cases are 63 only. It surly sounds like your case is a replacement case for 63 , Was it stamped at all with a assy. stamp?
              • Timothy B.
                • April 30, 1983
                • 5177
                Edward,
                Yes, it has an assembly stamp and it's K2222, that's all that was there and I had the serial # stamped into it because I could not find the original transmission. I don't have a picture of that side to post.
                Attached is a picture of the main case showing what I am talking about. I need to correct the casting date I reported, it looks like (K) (4) but no year. I think there is no (I) used on these T-10's so the date would be October 4 if I got it right. My coupe was built second week November 62.
                Looking at the pics, there is a B cast above then K in one boss then 4 in the other raised boss but on most there is then a 62 or 63 next where this one does not have that.
                • Kenneth S.
                  • July 31, 1981
                  • 302
                  My ’63 was built April 18, 1963. The T-10 dates were: assembly March 12, 1963, Main Case B 27 63 (Feb 27, 63), Side Cover dated 12-12-62, Tail T10-7D, 3813490, Dated 2-8-63.
                  Ken
                  • Harry S.
                    • July 31, 2002
                    • 5258
                    Close ratio or not?
                    • Loren L.
                      • April 30, 1976
                      • 4104
                      Various dates and correlatons would be very interesting IF transmisions were used on a First In, First Out basis, but they were not, either at time of assembly or when installed in St Louis.
                      • Bill C.
                        • June 25, 2007
                        • 106
                        My 63 was built Sept. 27,1962. Some dates on my T-10 are:
                        Assembly date, August 10,1962
                        Tail, T-10-7D, dated May 25,62
                        Bill
                          • 6940
                          Originally posted by Harry Sadlock (38513)
                          Close ratio or not?
                          Harry, Its my understanding that the close ratios transmissions were installed only on the SHP motors. Does that sound correct?
                          • Kenneth S.
                            • July 31, 1981
                            • 302
                            Close ratio or not?
                            Gear Ratio Code QQ 2.54 1.89 1.51 1:1
                            Ken
                            • Harry S.
                              • July 31, 2002
                              • 5258
                              That's correct. Looking to see if there is a timeline difference between 250/300 and 340/360 on Trans build dates.
