Re: dash cluster
I tried that trick for the removal, but I didn't care for it. Perhaps it will work better for the re-install. I actually used a set of 6" long 1/4-20 bolts, the threads only go about an inch or so and the rest in nice and smooth for an easy glide.
I found the biggest challenge was removing the connector for the ignition switch. It was after I got the cluster out that I learned the correct procedure for using the paper clip to remove the ignition switch still attached. 55 years of turning a wrench, and NOW I learn the damn trick? Aaarg!
