About to order the CS165R cam for '68 427/435 build. The old cam PN3863144 has what looks like the rear groove I have read so much about (photo). From research my motor is '73 CE block 3999289 427 build up not 454 configuration. This is the cam that came installed. From earlier thread '03:
"...only the 65 and 66 BBC need the groved rear cam journal. if you use a grooved cam in a later block you have a big oil loss internally and this could could cause you valvetrain wear because not enought oil is getting to the parts."
My reason for rebuild was a couple bent pushrods, flattened lobes, couple toasted piston tops. I thought it was lack of valvetrain adjustment + maybe bad gas but could it have been the grooved cam. I want to order the CS165R cam without the groove but if I do so are there other precautions needed to ensure proper oil flow to valve train. Thank You!!
I would highly recommend using CJ-4 oil after reading this article, scroll down to page 3:
