75 roadster rear cover hinges - NCRS Discussion Boards
  • Ross F.
    • August 31, 2004
    • 167
    Ok, I give. Is there some secret to getting to the top bolts that hold the hinge assembly to the body? I'm about 2 hours and a pint of blood into this and don't have one of them out yet.
    Going in the house for a beer and wait for your help.
  • Mark S.
    • February 1, 2002
    • 110
    Re: 75 roadster rear cover hinges
    Are you refering to the base spring mount inside the body? If so that is the rear body mount, access head inside the rear wheel well.
    • Ross F.
      • August 31, 2004
      • 167
      Mark, correct.
      The hinge spring assembly has 3 bolts one attaches to the #4 body mounts and 2 attach to the rear deck. I can't for the life of me get to those bolts.
      • Russ S.
        • April 30, 1982
        • 2161
        Ross, Why do you need to remove the hinge? I have had to install them for some one before and they are definitely very hard to get to.
        • Mark S.
          • February 1, 2002
          • 110
          Body bolt #4 uses a captured nut or caged nut as part of the lower spring mount iside the car, these are almost always rusted out thus just a pair of vise grips there. If it's the top 2 bolts attaching the fiberglass lid, those have a tapped rivot plate mount just like your hood hinge, seat mount etc. Here is the most recent C3 repair for me, this is one for the scrap pile.75 005.jpg
          • Ross F.
            • August 31, 2004
            • 167
            Mark, I think you are showing me the bottom of the lid. I need to get to the bolts holding the hinge to the body.
            Russ, both of my #4 body mount reinforcement bracket and caged nuts are rotten. I need access to rivet in the New ones. I also need to do some glass work on the right #4 pocket as the nut pulled through the body when the reinforcement bracket failed.
