Hi Folks,
I recently acquired a 1977 L48 4-speed from the original owner and joined NCRS on 2/28/14. The Vette has 41,120 miles currently and looks to be mostly original. I was doing some clean up over the weekend and discovered that the passenger-side front caliper is leaking fluid past the dust seals, so it's time to either rebuild or buy replacements. The part number on the outer half (didn't check inner) is 5452273, so I think this is a correct part for the '77.
I've not had time to disassemble the caliper, but I'm assuming that if it is original, it will need to be bored and sleeved. Several vendors have calipers (some new, some rebuilt), and I'd like to know of anyone has experience with the calipers from Duntov, CSSB, Lonestar, Muskeegon, or NAPA/Advance/AZ/etc. Ideally, I'd like to have correct numbers on the calipers. I'm also planning on replacing/servicing the driver-side front caliper too.
On my driver-side rear caliper, it is number 5452384, so I think that is correct. The passenger-side rear caliper is marked "H5G" or "H56" (hard to read that last character) so who knows what that is. Both rear calipers look to have been replaced, and the parking brake cable looks to been replaced too.
Any recommendations and thoughts about rebuild vs. replace are appreciated. Also, do Duntov, Muskeegon, etc do their own rebuilds, or are they reselling someone else's calipers?
One last thought...does anyone make a reproduction rubber brake line for the front and rear that have the "DOT" labels on them? I'm guessing mine are original, but they look okay, are flexible, and nothing is leaking, but it is probably prudent to replace them. Thank you.
