Could someone post a photo of the right dash cluster tab on a C2 (where the screws holding the dash cluster screws into the clip)? Mine was broken off and I've built up some new fiber glass but I need to know how to cut of the glass to mimic what was originally there...
C2 Dash cluster tab
Re: C2 Dash cluster tab
Rob,
I had the same problem. One tab was broken. I took a metal washer and placed it behind the broken tab so that the hole where the screw would go was close to correct (when the two were combined). I then scribed the washer at the point where the fiberglass had broken. Then I cut the washer and glassed it to the existing fiberglass tab (front and back). Finally, I drilled out the fiberglass and sanded it to match the other tabs. It worked great for me and I hope this helps.
I have a couple of pictures, but have problems uploading pictures to our site. PM me and I'll be happy to send them to you.Rob
'66 327/300 Regional Top Flt
'08 6 speed coupe- Top
Hi Bob,
I think I'm ok with the photo's received so far... thanks for your offer!
here is another one I received from Harry Sadlock:
DCP_0910.jpgRob.
NCRS Software Developer
C1, C2 and C3 Registry Developer- Top
