Last week installed the rebuilt 3247 Holley carb on my "66 and today went to fire it up. Engine cranked but did not fire so took a look under the hood and see that fuel leaked from fuel inlet area on both primary and secondary sides. However, it appears the leak is not coming from where the fuel line screws into the inlet but from area around the large nut behind the fuel inlet. When I installed the carb I first finger threaded the screw line nut into the inlet and then tightened pretty well with wrench. However, I did not check how tight the large nut behind the fuel inlet was when I got the carb back from the rebuilder. I am thinking about disconnecting the fuel lines, tightening the large nut and seeing if this solves the problem.
Any thoughts, this is my first time installing a carb? thanks
