Hello together
I am having a bit of trouble in finding out where some plugs are connected.
First (picture 334 + 340) found a plug with black/white wire hanging down in front of the wiper motor, I connected it then (picture 340), seems as this is a ground of the wiper motor, is this right? I already have the yellow/brown/blue plug attached to the wiper motor. It always worked as it should, washer pump works too, I was just curious about that ?ground wire(black/white hanging down)?
Second question(picture 341)
There are some wires hanging down on the right side of the car, near the heater motor. There is a black/white plug too, is this also a ground? And if yes, where do I have to connect that one?
Thank you in advance
